Timeline and Sequence issues in FCP...HEEELP ; )
Ron Moon
on Mar 31, 2010 at 7:49:48 pm
Hi guys,
So, here's the situation (Please forgive my novice FCP expertise):
I shot a video on my new Canon 7D (Which i LOVE!!!), and per the recommendations of several threads, i converted all the H.264 1920x1080 23.98 footage to Apple ProRes 422 HQ 1920x1080 23.98 in order to edit it in FCP.
So I spent several days cutting the whole video, and when i finally finished and exported out, it came out 720x480. Then I noticed my sequence settings were at 720x480, 29.97, DV/DVCPRO - NTSC (see pic below)
So first I altered my current sequence to match the footage, but it wouldn't let me change from 29.97 to 23.98. So then I created a new sequence with all the correct settings, and copy and pasted my cut into the new sequence and the problem i'm having is that for some reason the image is small inside a black 1920x1080 frame. (see pic below)
HEEEELP ; )
Thanks a bunch.
:::ron
:::ron
:::ronmoon.com
Shane Ross
Re: Timeline and Sequence issues in FCP...HEEELP ; )
on Mar 31, 2010 at 7:59:04 pm
Highlight all the clips, then right-click and choose REMOVE ATTRIBUTES. Click BASIC MOTION and DISTORT. MIght need to do FILTERS too, if there is the SHIFT FIELDS filter on all of them.
Didn't see the render bar above the footage? That is the FIRST CLUE that something isn't right. And FCP didn't ask to change the sequence settings to match your clip settings? Or did you COPY/PASTE into the sequence? IT doesn't ask when you do that.
Shane
Ron Moon
on Mar 31, 2010 at 9:44:54 pm
Awesome! that did it! thanks a bunch!!!
:::ron
:::ronmoon.com
