FCE 2-camera shoot rendering issue
Sam Brown
on Mar 30, 2010 at 12:39:35 pm
Hi there,
I hope someone can help - I'm pulling my hair out here!
I have FC Express and want to do a 2 camera shoot using 2 SD card HD cameras. I plan to use a separate soundtrack, recorded at the time, onto a high quality recorder using some nicer mics than the camcorders. I'll sync it up in the computer when I edit.
I can import the footage into FCE where it requires rendering. I render the files successfully. The problem is that when I move one of the files into another video track it needs to be re-rendered. In fact, with 2 video tracks stacked up I have to re-render whenever I move anything. Is there a way around this? Do I need Final Cut Pro?
Thanks in advance for your help,
Sam
John Fishback
Re: FCE 2-camera shoot rendering issue
on Mar 30, 2010 at 10:21:11 pm
In FCP this would be caused if your file's sample rate was not 48kHz. Check the sample rate of your audio files. If it's not 48kHz, use an external program like Soundtrack Pro or QT Pro to convert the audio to PCM 48kHz 16/24 bit. You can't do it successfully from FCP.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
