Unable to open file
David Blumenfeld
Unable to open file
on Mar 29, 2010 at 4:39:54 am
Hi...I was having a lot of crashes in fcp 6.06 -- spinning disk. I trashed preferences and now when I try to open the project I get "unable to open project file"... ANY SUGGESTIONS on how to get my project to open now? I had turned off autosave, as I thought this may have been the spinning disk issue...HELP!
I've tried opening it on 7-no luck
Tried FCS -no luck
ANy other suggestions? It seems like this file is corrupted--is there a service or software that may be able to "fix" it, before I start and re-edit this piece?
Robb Harriss
Re: Unable to open file
on Mar 29, 2010 at 1:20:15 pm
you can try:
http://www.digitalrebellion.com/
did you run disk software and repair permissions?
Non-linear: all the time and nothing but.
