How Is This Fast Edit Done? (Beyonce Video)
Lillian Young
on Mar 28, 2010 at 2:33:33 am
I love this fast edit effect in Beyonce's Videophone video at :40 in, and I'm wondering how it's done.
I assume it's cut frame by frame at a different point, but am I right in that assumption? Is it a plug-in? The movement flows so well, and I'd like to try it on a video I'm working on.
<object width="480" height="385"><param name="movie" value="//www.youtube.com/v/Xo982Z-cgOU&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/Xo982Z-cgOU&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Rob Grauert
Re: How Is This Fast Edit Done? (Beyonce Video)
on Mar 28, 2010 at 2:39:21 am
my friend did something similar to this in high school. all he did was show a few frames of each clip and alternate them. if it's done fast enough, i guess your brain just sees it as one image.
Robert J. Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com
cowcowcowcowcow
Andy Mees
on Mar 28, 2010 at 4:09:16 am
You can use the blink filter for this Lillian ... put your 2 video sources on 2 separate layers (eg v1 and v2) then apply the blink filter to the upper layer and adjust the settings to the rate you want that upper layer to flash on and off.
Have a look a Luca's Dual Flicker filter too, adds a really nice "randomness" to the whole idea and a great example of a good idea well realised:
http://www.videonline.co.uk/Lucas_Dual_Flicker.htm
Bouke Vahl
on Mar 28, 2010 at 8:20:24 am
the fastest way to cut is cut every field.
For that you need a key signal that seperates the fields.
An example here:
http://www.editb.nl/fielddominancechange/
If you use this as a matte between two layers, you get just a field of each one.
(put two clips on top of each other, apply image mask filter to the top one, drag my clip to the image setting)
If you watch on an interlaced client monitor, this will blink 50 / 60 fps
BUT, no idea how it will look after de-interlacing, and that will happen if you upload to Youtube or alike.
Bouke
http://www.videotoolshed.com/
smart tools for video pros
Jason Porthouse
on Mar 31, 2010 at 9:11:22 am
Uhhh... there's an effect? Where? Must've been distracted.
Serious Q though - I'm surprised this would pass the Harding test (photosentitive epilepsy) but I guess if the luminance values don't change much and the position of the centre of attention isn't changing, you might get away with it?
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you'll be a mile away. And have his shoes.
*the artist formally known as Jaymags*
