RED TO - PRO REZ 422 HQ -- Data Rate Question
Matthew Rundell
on Mar 26, 2010 at 4:02:57 pm
FCP 6.6 (Upgrading to 7 soon for upcoming project)
Injesting through Log and Transfer. In tests, I'm getting Apple Pro Rez 422 HQ into my machine at a data rate of 26 mbs, the frame size is 2k. I checked a white paper and the data rate for this codec was supposed to be over 200 mbs. Am I wrong here? My R3Ds are fine, shot 4k originals.
What's the data rate you guys know about for this codec? Is injest different in FCP 7 in regards to data rate?
Thanks.
Matt Rundell
Rob Grauert
Re: RED TO - PRO REZ 422 HQ -- Data Rate Question
on Mar 26, 2010 at 5:37:50 pm
that should be right.
8mbps = 1MBps
so 220mbps = 27.5MBps.
i think you're confusing mbps and MBps. mbps is megabits per second, while MBps is megabytes per second. the difference is 8 bits = 1 byte
Robert J. Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com
Matthew Rundell
Re: ED TO - PRO REZ 422 HQ -- Data Rate Question
on Mar 26, 2010 at 5:56:52 pm
Thanks Robert. Yes, sounds like I was confused. Easy to be with so similar naming conventions.
