 | Grey bars over exported video
on Mar 26, 2010 at 1:47:57 pm |
We exported our sequence from Final Cut Pro as a .mov using H.264 and when we played it back there were grey bars over the video does anyone knoe how to solve this?
 | Re: Grey bars over exported video on Mar 26, 2010 at 3:05:04 pm |
Why don't you upload a pic?
rafael
http://www.nagavideo.com | Re: Grey bars over exported video on Mar 26, 2010 at 3:16:18 pm |
Can you give any more detail? What are your sequence settings, how are you compressing..
 | Re: Grey bars over exported video on Mar 26, 2010 at 3:33:53 pm |
I experienced grey bars over the video as a watermark of an unregistered plug in.
Are you using any plug-in's on the video?
-Jason
 | Re: Grey bars over exported video on Mar 26, 2010 at 3:36:27 pm |
Hi Alice,
It sounds like you have installed one of our Calibrated{Q} Decode codecs - as we do have a gray watermark when using our software in DEMO MODE. Also, just a FYI - our Calibrated{Q} Decode codecs are not meant for Mac computers with FCP installed.
To uninstall our software just:
1. Delete the Calibrated folder from the Applications directory
2. Delete the Calibrated*Codec.component from the /Library/QuickTime directory (that's the Library folder on the Main harddrive not the Library folder in the User directory) - not sure which Decode codec you may have installed so the * is what the name of the codec would be.
3. restart
and that should be it.
Cheers,
Greg
Calibrated Software
