applying crossfade to multiple audio cuts at once
Tony Asimakopoulos
on Mar 25, 2010 at 7:11:05 pm
Hello!
I know this is probably a basic question, but I can't find the answer in the manual. I need to apply a simple 2-frame crossfade to all my audio cuts. There's gotta be a way to select all the clips/edits and do them all at once. But how? :)
thanks!
Tony
John Fishback
Re: applying crossfade to multiple audio cuts at once
on Mar 25, 2010 at 7:53:01 pm
Select all the clips then Command+Shift+T will apply the default audio fade between all clips.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Tony Asimakopoulos
on Mar 25, 2010 at 8:29:41 pm
Thanks John,
Just tried it - no luck though! What could I be doing wrong?
Tony
John Fishback
on Mar 25, 2010 at 9:20:40 pm
So sorry, it's Command+Option+T.
John
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Tony Asimakopoulos
on Mar 25, 2010 at 9:35:27 pm
Hi again John!
Thanks for your patience. It's still not working for me...odd. Perhaps I'm selecting wrong? Is theer a way to select multipel clips so you see the "trim" color at each cut? Because it seems you can only apply a crossfade when you're in trim mode, or whenthe "cut" itself is selected.
thx
Tony
John Fishback
on Mar 25, 2010 at 10:47:30 pm
I think this only works in FCP 7. I used the single right-facing arrow selection tool (press T once) to select a bunch of clips and Cmd+Opt+T. You can select them however you like.
John
Matthew Currier
on Oct 11, 2010 at 8:28:18 pm
I was looking for a way to do the same thing. Have you figured out a way?
I'm using FCP 6.06
Tony Asimakopoulos
on Oct 12, 2010 at 11:46:02 am
Sadly, I haven't! Doesn't seem to be a way.... let me know if you figure it out!
Rafal Kos
on Nov 27, 2010 at 7:34:11 pm
This is easy. Select all your clips (COMMAND + A) in the timeline, then go to your browser, choose Effects > Video Transitions > Cross Dissolve, then drag "Cross Dissolve" onto the clips. Voila.
Garrick Enright
on Apr 15, 2014 at 8:33:48 pm
The hotkey is CMD+SHIFT+D
