clips only partially exporting??
Harry Dawson
on Mar 25, 2010 at 4:21:53 pm
Prepping for color so want to bake some clips but Final Cut only exports a portion, not the whole thing. Tried all ways, trashed prefs, etc. Puzzling, has not occurred before. Anyone else?
Andrew Evans
Re: clips only partially exporting??
on Mar 25, 2010 at 6:28:11 pm
What version of color and final cut are you using? With color 1.5 and fcp 7 you don't need to bake clips anymore. Are you copying the clips you want to bake into a new sequence and then exporting?
You just need to give some more details here to get a better response.
-Andrew
Harry Dawson
on Mar 25, 2010 at 6:49:30 pm
Final Cut Studio. Yes, I was trying all things, including putting into a new sequence for export. I was trying to export to ProRes from DVCProHD. Found that if I exported as "current settings" meaning DVCProHD then transcoded in Compressor it works ok, but not straight out of a timeline with the section selected; it never exports the whole clip! Have a workaround now, still curious though.
BTW, I have somewhat of a potpourri (my own doing) of Codecs in the timeline, thus am going to Color in several steps.
