Final Cut's "Finder" ""browser bar" opens slow
Phil Yunker
on Mar 24, 2010 at 4:35:21 pm
Not sure if this is the correct name for it but FCP's "Finder" or browser bar opens slow.
For example, when I click on any of the items (file, edit, view, mark, modify, sequence, effects, tool, window, help) they don't open right away, usually 2-3 seconds, it's has gone past annoying and now it's really p&ssing me off.
It seems to do it when I click on a different window (Viewer, canvas, Browser, timeline) then go to, for example "modify" it will take 2-3 seconds to open. Then when I move over to "mark" it will open immediately. Then when I click on a different window, for example the "browser" then back to "modify or "mark" or any of the items on the browser / nav bar / finder it takes 2-3 seconds to open. This also happens if I use the keyboard (not just the mouse) to select the window then try to click on one of the above items.
I had 16GB of RAM in the system, I took it out and put in the original 2 GB of RAM to see if that would help (advice from a engineer friend) it did not help this problem but it might have cleared up another problem (more on that in another thread possibly).
Any suggestions?
FCP VER. 6.0.6
System:
10.5.8
2 x 3.2 GHz Quad Core-Intel Xeon
2 GB RAM (removed the 16GB RAM) WIll be putting it back in
ATI Radeon HD 4870 /512 MB VRAM
monitors - 1 x Samsung Synchmaster T240HD
1 x Samsung Synchmaster T260
PHIL YUNKER
Yunker Video Production Services
http://www.philyunker.com
http://www.linkedin.com/in/philyunker
John Fishback
Re: Final Cut's "Finder" ""browser bar" opens slow
on Mar 24, 2010 at 4:50:39 pm
If you haven't trashed FCP prefs and Repaired Permissions try that. It's the 1st thing to do when FCP suddenly gets weird.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Phil Yunker
on Mar 24, 2010 at 5:46:46 pm
John,
Thanks. Yes I've done all that, no luck.
PHIL YUNKER
Mike Kahn
on Mar 26, 2010 at 3:01:09 pm
Try creating a new user account and opening FCP. Sometimes there are preferences that go bad that you don't know about and simply creating a new user will fix this issue. If it does fix it, you can copy your files from one user to the other and delete the bad user.
Phil Yunker
on Mar 26, 2010 at 3:05:27 pm
Mike,
Thanks. I'll try that.
PHIL YUNKER
