Import and Transfer - Red and Canon
Adam Howden
on Mar 23, 2010 at 9:14:54 am
I've recently upgraded to a Mac Pro. I've installed all the apps and plug in and drivers. So it's totally up to date as far as I can tell.
I've been trying to import and transfer some RED and Canon 5D footage and don't seem to be having any luck at all. I can see the preferences tab for both the Red and the Canon but when I go to select the folders or files none of them will show up in the Log n Transfer window...
Any thoughts?
Thanks...
1 X 8-Core Mac Pro Xeon 2.8 Ghz
10 GIG RAM
Final Cut Studio, Adobe Creative Suite etc
Pepijn Klijs
Re: Import and Transfer - Red and Canon
on Mar 23, 2010 at 10:41:17 am
You have to keep the original folder structure as it was created by red to be able to see them appear. It works perfect for me in fcs 3 log and transfer tool with the red r3d footage.
Good luck!
Avid/FCP Editor, Amsterdam, The Netherlands
http://www.pepijnklijs.nl
Alex Elkins
on Mar 23, 2010 at 10:42:22 am
Hi Adam,
Can you go through in some more detail the steps you are taking, and it'll be clearer where you're going wrong - or if all the steps are correct then you're probably still missing drivers/plugins/updates.
Alex Elkins
Salad Daze Films - Freshly Tossed
Read my blog!
Ben Holmes
on Mar 23, 2010 at 11:53:40 am
Both types of media require the original folder structure on the CF cards or drive used. If you have consolidated the media only onto another drive, you may not be able to use log and transfer. There is pretty good documentation with RED (the whitepaper included with the FCS installer) and on Canon's website (I think).
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
John Fishback
on Mar 23, 2010 at 5:52:22 pm
For the 5D here's a link to the Canon plugin. Be sure to select Mac OS X to see the plugin download link.
Here's a page about using the plugin.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
