Final Cut Timeline RT editing with trancode Red one footage
Chuska Esteban
on Mar 22, 2010 at 5:33:19 pm
Editing with Final Cut, transcode footage from Red One, as Apple Pro Res 422(LT)
Why my timeline, the RT, appears as Play Base Layer Only. I can not see the entire options of Unlimited Rt or Safe Rt. In wich maner this affects to my editing.
Thank you, very much
Kevin Monahan
Re: Final Cut Timeline RT editing with trancode Red one footage
on Mar 22, 2010 at 8:04:47 pm
Go to Sequence > Settings and what are the codec settings? Is it set to H.264 or something?
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Chuska Esteban
on Mar 22, 2010 at 9:10:39 pm
Hi, Thank you for your answer.
The settings of the sequence is Apple Pro Res 422 HQ, I guess that the footage it´s hard to process, so that´s why on the Timeline RT you can not decided if could be unlimited RT or safe. It directly tells you that it is only. Play BAse layer only.
Is this correct? Any sugestion?
Thank you!!!!
