FCP 7.0.1 Multiclip editing with 4 sources?
Brian Lettieri
on Mar 21, 2010 at 3:49:37 am
We just installed FCP 7.0.1 and Kona3 7.1 and have set up a 4 camera multi cam edit. When the 4 sources are viewed in the viewer there is an almost 2 second delay to the program monitor. However when only 3 of the sources are created in multicam the monitor timing is perfect. Has anyone ran into this problem and does anyone have a fix? Thank you.
Shane Ross
Re: FCP 7.0.1 Multiclip editing with 4 sources?
on Mar 21, 2010 at 5:18:34 am
What hard drive is this footage stored on? And what codec is the footage? Important details...
Shane
Brian Lettieri
on Mar 21, 2010 at 5:54:19 am
Shane we have a San for storage and the codec's are DVCProHD720.
Shane Ross
on Mar 21, 2010 at 6:04:04 am
Connected via fiber? Gig Ethernet? Is it rated fro video?
Have you run a drive test on it (the AJA one or Decklink one) to see what read-write speeds it gets?
Shane
Brian Lettieri
on Mar 21, 2010 at 6:16:52 am
Shane
We are fiber connected. FYI last week using G5's and FCP 6.0.2 it worked perfectly. I just created a multiclip using 4 streams of SD [DVCPro SD 525] and it worked perfectly.
Brian
Brian Lettieri
on Mar 21, 2010 at 4:46:30 pm
We found the RT settings were in Dynamic which seems to have caused the problems. We changed settings to Unlimited RT with Playback VideoQuality = High and Playback Frame Rates = Full fixed the problems. Just the opposite of the settings for FCP 6.x. Thanks for your help Shane!
