P2 Import into FCP missing files!
Dan Bennett
on Mar 20, 2010 at 12:56:44 am
So I have this project working in Standard Def off of HVX P2 cards.
The cards have been trasnfered to a hard drive and I'm properly using the LOG AND TRANSFER in FCP.
However, I've noticed that while the files loud in the Log and Transfer window, when I look in the Video Folder under Contents, there are more MXF files there, than what the Log and Transfer window is showing me.
For example.
I add custom path, choose CAM 1 Card 1> and it loads 5 clips into the Log and Transfer window.
They import fine. But, when I double check the CAM 1 Card 1>Contents>Video folder, i see 7 MXF files.
can anyone tell me whats going on here?
Now, I'm working with a LOT of footage, 3 days worth on 3 cameras, each with half a dozen cards used.
Shane Ross
Re: P2 Import into FCP missing files!
on Mar 20, 2010 at 1:24:00 am
P2 cards are formatted FAT32, so they have a 4GB limit. So when you record LONG takes, the cards break up the takes into multiple parts. So while you might have 4 clips, FCP sees them as one continuous clip and joins them together. You might see in the L&T interface that some of the clips say SPANNED. Those are clips that are grouped. Some might span from one card to the next.
This is normal.
Shane
Dan Bennett
on Mar 20, 2010 at 1:34:32 am
Thankyou so much! That makes so much sense!
You just saved me a crap load of stress!
Shane Ross
on Mar 20, 2010 at 1:57:59 am
I was in your same shoes when I first got footage from the camera. But the workflow was VERY rough back then too. I was kinda stressed about that as well.
Good Luck
Shane
