FCP on a Macbook Pro
frederico silva
on Mar 19, 2010 at 4:13:20 pm
Hi there
I have a Macbook Pro with 2.4Ghz Core2duo, 2GB ram.
I have a sequence with 920x720 with a video(originally 1920x1080)
the Video has 1min and 21 sec.
And just a few effects like: 3 color balance filter, 1 -Sharpen, 3 Magic Bullet filters(LS bleach, LS NÂș 85, MisFire Vignette), Color corrector 3way, Frames(Magic Bullet de-interlace filter)
it takes like 10 hours to export to quicktime(current settings)
I dont have experience in editing HD, and using color filters. Is this a acceptable rendering time?
What is your experience with a similar system and FCP color adjustments or AE in terms of rendering time?
Fred
Shane Ross
Re: FCP on a Macbook Pro
on Mar 19, 2010 at 5:32:44 pm
You said the dimensions, but NOT the codec. What codec? DVCPRO HD? ProRes?
[frederico silva] "I have a sequence with 920x720 with a video(originally 1920x1080) "
Those are VERY odd numbers. Not a normal ratio for FCP. If the sequence settings and footage doesn't match something you find in the Easy Setups, then yes, they can take a long time. But also, you have a LOT of render intensive filters, like FRAMES. That does take time too. You have a lot of factors that are adding up to a long render time.
Shane
Sam Ellens
on Mar 20, 2010 at 12:33:36 am
The only 960x720 footage I've seen came from DVCPro HD 720, but I rarely get 720 footage.
and I love that this is considered a small number of filters by some. renders take a long time, and they take even longer on a macbook pro.
Sam Ellens
Intern - Zamasti Films
4th year at Ryerson University - Radio and Television Arts
My system: iMac 21.5 3.06GhZ 4GB
