re naming in compressor
Tom Partridge
on Mar 18, 2010 at 2:05:34 pm
This is really a Compressor question but I couldn't see a forum specifically for that, I thought I would try here...
I am trying to export an image sequence (tiff) from my final cut pro using compressor but every time I do this the outputted files are being renamed.
When I send the sequence into compressor my file name it displays is correct -
ww123_455_actRefFACE_FRONT-half_hd_tiff.tiff but the outputted files are named as frame-000000.tiff, frame-000001.tiff, frame-000002.tiff etc rather than keeping the original sequence names.
I can't seem to find any naming options in compressor.
I have tried to do this using a droplet, and having the name just be set to source but this produces the same results
Quicktimes don't have this problem.
Tom.
Arnie Schlissel
Re: re naming in compressor
on Mar 18, 2010 at 4:11:03 pm
You can use Automator to rename the files.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Tom Partridge
on Mar 18, 2010 at 4:30:45 pm
Thanks Arnie but I need to export over 100 small sequences so it is impossible to keep track of them if the naming has no resemblance to the source.
