sequence setting for JPG files ?
Heike Dowidat
on Mar 17, 2010 at 9:27:13 pm
Help: What is the best sequence setting for JPG pic files? I only edit with JPG files in this project, a big picture montage.
Right now I use: DVCPRO HD 1080i60. When I move pictures through the screen they start to jitter and don't move smooth after I render everything out. My software is Final Cut Pro 7.
Michael Gissing
Re: sequence setting for JPG files ?
on Mar 18, 2010 at 1:06:31 am
What is the final output/ destination? Broadcast? Web? DVD? BluRay?
Unless we know what it is going to end up as it is impossible to advise a sequence setting or workflow.
Heike Dowidat
on Mar 18, 2010 at 1:30:30 am
Hi there, the final product is for the Web and for DVD.
Michael Gissing
on Mar 18, 2010 at 8:59:01 pm
Then a standard def ProRes would be best. Depending on the sort of DVD you require, either 29,97 for the NTSC market or 25 frames if it is PAL. The web doesn't care.
Make sure the sequence settings have fields set to none so there is no interlacing.
