Outputing 23.98 psf to HDCAM SR
Chris Borjis
on Mar 17, 2010 at 7:07:09 pm
The fcp timeline is 1080P 23.98 prores (from red)
The deliverable is HDCAM SR 4:4:4 23.98 psf
Just curious, will I have to use dual-link to output to the SR deck?
or do I just put it the deck in 4:4:4 23.98 psf mode and it captures via single HD-SDI connection
since the timeline is ProRes?
any input appreciated.
Shane Ross
Re: Outputing 23.98 psf to HDCAM SR
on Mar 17, 2010 at 7:23:56 pm
[Chris Borjis] "Just curious, will I have to use dual-link to output to the SR deck? "
For 4:4:4...yes, you do. You will need a Kona 3 for this.
Shane
Chris Borjis
on Mar 17, 2010 at 7:41:44 pm
I have a multibridge extreme with Dual-link, that should work right?
Shane Ross
on Mar 17, 2010 at 7:42:48 pm
Yes, sorry. I'm KONA/MAtrox minded. If the Decklink has Dual Link, then you will need to use both to get 4:4:4.
Shane
Chris Borjis
on Mar 17, 2010 at 7:44:24 pm
do I have to change the easy setup or sequence to enable it though?
if so my only option is RGB 8-bit 4:4:4 is that right?
UPDATE: Ah I see a "enable 4:4:4 output" on the multibridge control panel
Shane Ross
on Mar 17, 2010 at 7:58:08 pm
[Chris Borjis] "do I have to change the easy setup or sequence to enable it though"
No. That is done via the software interface of the card. HOW? I dunno, I know AJA and Matrox products.
[Chris Borjis] "if so my only option is RGB 8-bit 4:4:4 is that right? "
Uh, 4:4:4 is 10 bit...and 12 bit, but I think the card is limited to 10-bit.
[Chris Borjis] "UPDATE: Ah I see a "enable 4:4:4 output" on the multibridge control panel "
AHHH...THERE YOU GO.
Shane
