Weird audio problem
Jacob Weldon
Weird audio problem
on Mar 17, 2010 at 1:45:09 am
Here's the problem:
When playing back my sequence, the audio on the track starts off in only one channel, then the other kicks in with about a 2 second delay and it's lower pitch. Any ideas?
Jerry Hofmann
Re: Weird audio problem
on Mar 17, 2010 at 4:49:20 am
Try mixing down the audio. If that fails, recapture the the audio, or rebuild it from whatever it's source is.
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
John Fishback
on Mar 17, 2010 at 6:47:34 pm
Is your audio 48k and 16/24 bit? If not, try converting it to those specs outside of FCP (in QT for instance) and then re-import.
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
© 2018 All Rights Reserved
