2nd Default Transitions?
John Keith
on Mar 16, 2010 at 8:08:55 pm
Is there a way to set a 2nd default, in addition to command-T for transitions, so you can quickly throw down either a 1 sec or 10 frame dissolve?
John Fishback
Re: 2nd Default Transitions?
on Mar 16, 2010 at 10:15:54 pm
You can drag both transitions to a bin in the browser (just drag the transition from the timeline) and then drag the desired transition from the bin to an edit point each time you need it.I don't know of a way to have 2 default transitions.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Kevin Monahan
on Mar 16, 2010 at 11:29:59 pm
Easy - save them as Favorites and then use the keyboard shortcut:
Transition Favorite #1 - CNTRL + Shift + 3
Transition Favorite #2 - CNTRL + Shift + E
Transition Favorite #3 - CNTRL + Shift + D
Transition Favorite #4 - CNTRL + Shift + C
Transition Favorite #5 - Assign your own shortcut in the Button List or Keyboard Layout
Transition Favorite #6 - Assign your own shortcut in the Button List or Keyboard Layout
Transition Favorite #7 - Assign your own shortcut in the Button List or Keyboard Layout
Transition Favorite #8 - Assign your own shortcut in the Button List or Keyboard Layout
Transition Favorite #9 - Assign your own shortcut in the Button List or Keyboard Layout
Hope this helps you.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Kevin Monahan
on Mar 17, 2010 at 12:14:02 am
Sorry! Those shortcuts were for Audio Transitions:
Transition Favorite #1 - CNTRL + Shift + 1
Transition Favorite #2 - CNTRL + Shift + Q
Transition Favorite #3 - CNTRL + Shift + A
Transition Favorite #4 - CNTRL + Shift + Z
Kevin Monahan
