Automate fades?
John Keith
Automate fades?
on Mar 16, 2010 at 8:05:21 pm
Is there a way to copy/paste automation when you have audio open in the viewer? Would be nice for dipping mouth noises at the beginning of each shot..
John Fishback
Re: Automate fades?
on Mar 16, 2010 at 10:19:07 pm
You can try pasting attributes using levels. Make an audio edit the way you want it, copy it, then paste attributes-levels. The only problem is you'll still have to adjust the nodes for timing. But, it might save a little time.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
