Exporting Sequences Tip
Wayne Carey
on Mar 11, 2010 at 9:26:23 pm
Hey gang...
I'm sure that some of you know this.... but... If you export using Batch Export from the File menu, your export times will be much faster than using the Export from the File menu.
Try it... You'll see.
_______________________________
Wayne Carey
Schazam Productions
http://web.mac.com/schazamproductions
schazamproductions@mac.com
Jeremy Garchow
Re: Exporting Sequences Tip
on Mar 11, 2010 at 9:39:41 pm
I use batch export all the time, even mapped a keystroke to it.
Matt Lyon
on Mar 12, 2010 at 5:10:44 am
Hi Wayne, in what situations are you getting a speed improvement? I didn't get much of a difference doing a couple tests with either "normal" exports or "using quicktime conversion." I'm on FCP 6 though ... not sure if it matters.
Matt Lyon
Editor
Toronto
Wayne Carey
on Mar 12, 2010 at 5:17:04 pm
I'm not 100% sure this is only a FCP 7 thing or not. But, outputting ProRes422 and XDCAM HD sequences seem to output much much faster for myself.
Besides, you can output more than one sequence at a time doing this... Some of us end up with multiple versions of a program and we need to keep shelf masters of each. Exporting all of the sequences at one time makes more sense.
Wayne Carey
Schazam Productions
