RT Drop down in sequence
Mike Allen
on Mar 11, 2010 at 5:59:27 pm
Why do the options in the RT Drop down (in upper left hand corner of the sequence) sometimes change. Sometimes is just have 2 options and sometimes I have several.
Mike
Shane Ross
Re: RT Drop down in sequence
on Mar 11, 2010 at 6:10:31 pm
When you use a codec that doesn't appear in FCPs Easy Setup list, your RT options are fewer. Do get all the options, you must work with a format that FCP can edit easily.
Shane
