Capturing DigiBeta to ProRes
Andrea Stewart
on Mar 9, 2010 at 5:03:21 pm
I'm capturing through an AJA IO SDI. I thought I would edit in ProRes in order to save drive space and make use of my multicore. In the past I've always worked in 10bit uncompressed start to finish.
Is there a way to capture using the ProRes codec from my AJA?
-Andrea
Andrea Stewart
Producer/Editor/Director - Owner
Germane Creative LLC
Rafael Amador
Re: Capturing DigiBeta to ProRes
on Mar 9, 2010 at 5:11:04 pm
In the "Capture Presets" duplicate the one you use for 10b Unc; edit the preset and change the codec to the Prores flavor that you want.
Rafael
http://www.nagavideo.com
Andrea Stewart
on Mar 9, 2010 at 5:16:43 pm
Cool. Thanks Rafael. Just did that.
Can I confirm that when working in NTSC I want to make sure I go to advanced and click capture interlace Lower Field first.
Also will there be any advantage to capturing ProResHQ when working from Digibeta? And would I get drive space savings vs 10bit uncompressed?
Andrea Stewart
Rafael Amador
on Mar 10, 2010 at 1:23:26 am
[Andrea Stewart] "Can I confirm that when working in NTSC I want to make sure I go to advanced and click capture interlace Lower Field first. "
Don't worry about this.
FC won't allow to build a capture preset NTSC 10b "UPPER FIRST". Only Lower.
[Andrea Stewart] "Also will there be any advantage to capturing ProResHQ when working from Digibeta? And would I get drive space savings vs 10bit uncompressed? "
Everything will be easier and you will achieve the same quality.
rafael
