Reconnect Media Crashing
Mason McKrakin
on Mar 8, 2010 at 9:32:35 pm
Final Cut Pro instantly crashes when I reconnect media in this certain project file. I successfully reconnected all the video. Then when reconnecting the audio, I direct it to the right file, click okay, crash.
Jerry Hofmann
Re: Reconnect Media Crashing
on Mar 10, 2010 at 2:08:42 pm
If you're selecting a single file to be reconnected, and it's crashes on that file, it's very likely that the file is corrupted, and you need to either reimport it altogether, or if you can't, rebuilding it and exporting it as an aiff might work to repair the file. Does the file open OK in Quicktime? If so you can export it from there... What is the source of the audio? what format is it?
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
© 2018 All Rights Reserved
