Avid to FCP color/gamma/levels shift... sometimes
James Weber
on Mar 5, 2010 at 7:09:44 pm
For a client, I'll often work with an Avid editor.
He'll send me a video on XDCAM, in XDCAM HD1080i60 format, and it'll look wonderful. But then, he sends me a section of the video over the internet to fix a typo or whatever, which he exports as XDCAM HD1080i60.
When I put the section I received over the internet into my timeline, the color is drastically different than what I received on the XDCAM disc. Everything looks washed out. Blacks are not at 0, and whites aren't at 100%. It's next to impossible to match the colors with the Color Corrector.
Any idea what is happening? Is this a problem on the Avid side, the FCP side, or is it just a lost in translation thing?
Final Cut tutorials from around the web- all in one place.
http://www.fcptutorials.com
http://www.jamesnweber.com
Jeremy Garchow
Re: Avid to FCP color/gamma/levels shift... sometimes
on Mar 5, 2010 at 7:45:42 pm
Check to see how fcp is interpreting the gamma. In the browser select the Show Gamma column.
John Pale
on Mar 5, 2010 at 8:38:25 pm
Avid has a setting for RGB or 601/709 for export.
I think FCP expects RGB, try both settings to be sure.
Jeremy Garchow
on Mar 5, 2010 at 8:40:15 pm
That was my next line of questioning. You beat me to it!
Jeremy
James Weber
on Mar 5, 2010 at 8:55:21 pm
I sent an email to see what his settings are.
James Weber
on Mar 5, 2010 at 8:56:53 pm
Neither clip shows anything in the Gamma Level Column, or with a CMD-9.
Jeremy Garchow
on Mar 5, 2010 at 9:13:17 pm
[James Weber] "Neither clip shows anything in the Gamma Level Column, or with a CMD-9. "
OK. Next is what John said.
James Weber
on Mar 17, 2010 at 10:44:38 pm
Got a test clip back, exported as RGB instead of the 601/709 he normally uses. It's a huge difference, much better, and matches the footage I import from XDCAM. Problem solved. Thanks!
