MPEG-1 Compressor questions
Sergio Deustua
on Mar 4, 2010 at 5:12:44 pm
Hello everybody.
Here I have two Questions about Compressor:
1.-
I have to make this little MPEG-1 video for a bank cash dispenser. My client specifies that the bit rate must be 1.140.000 bits p/s. The quality I get using this bit rate is just awful. Is this rate to low and I must use a higher one?, must I tell this to my client?
2.-
The MEPG-1 preset in Compressor does not allow me to change the frame dimensions of the video. The option to do this exists but it´s blocked. How can I change the frame dimension using MEPG-1 preset?
Thanks and have a good day.
John Pale
Re: MPEG-1 Compressor questions
on Mar 4, 2010 at 6:34:10 pm
Compressor only makes MPEG-1 that conform to the DVD spec. No choices for customization.
Some other 3rd party compression programs offer choices.
Tom Wolsky
on Mar 4, 2010 at 7:56:08 pm
You can change the MPEG-1 settings by copying it. The data rate is pretty limited and the default is the usual rate used for VCD that MPEG-1 is usually used for.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Jeremy Garchow
on Mar 4, 2010 at 7:00:49 pm
MPEG-1 is usually a fixed dimension and terrible quality. What you are seeing is probably accurate.
Sergio Deustua
on Mar 12, 2010 at 11:42:54 am
Thank you guys.
Rafael Amador
on Mar 12, 2010 at 12:40:17 pm
And, if you are working with interlaced footage,don't forget to de-interlace.
rafel
http://www.nagavideo.com
