Final Cut noise reduction plug-in
Thomas Winston
on Mar 4, 2010 at 4:28:36 pm
I'm looking for a noise reduction plug-in for Final Cut. I used one before that worked great that I thought was put out by FXfactory, but I can't seem to track it down. Any suggestions are much appreciated.
THX!
Thomas
Thomas Winston
EP/DP
Grizzly Creek Films
http://www.grizzlycreekfilms.com
Dave LaRonde
Re: Final Cut noise reduction plug-in
on Mar 4, 2010 at 5:38:20 pm
[Thomas Winston] "I'm looking for a noise reduction plug-in for Final Cut."
It's called "Apple Soundtrack Pro". Learn how to use it.
Dave LaRonde
Sr. Promotion Producer
Thomas Winston
on Mar 4, 2010 at 6:14:51 pm
Sorry if I wasn't clear, I'm asking about visual noise in the picture, not the sound.
Thomas Winston
EP/DP
Grizzly Creek Films
Colin McQuillan
on Mar 4, 2010 at 6:22:00 pm
Not all 'noise' is audible!
I infer the OP is talking about picture noise.
Colin McQuillan
Vancouver, B.C.
Colin McQuillan
on Mar 4, 2010 at 6:38:09 pm
The version of Core Melt that shipped with ver1 of FX Factory had a plugin called Noise Limiter. Works OK.
The Noise Industries Noise Reduction plugin does a decent job if its just a touch you are after. Anything more and it just blurs the picture beyond use.
Nattress has a few decent noise reducers (Chroma, Spatial, and Temporal,) though I have found they only render properly when timeline renders are set to 8-bit only.
Any of them need to be used sparingly and wont completely remove the noise/grain from a shot. Adding a touch of sharpen helps keep the defining lines in check.
Colin McQuillan
Vancouver, B.C.
Phil Balsdon
on Mar 4, 2010 at 7:38:55 pm
Neat Video is excellent, but you have to pay for it.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
http://www.steadi-onfilms.com.au/
Paul Dickin
on Mar 5, 2010 at 9:29:05 am
[Phil Balsdon] "Neat Video is excellent..."
Hi
Having got by (= struggled) with the various freebie noise reducers I recently bought the Neat Video plug-in - which is magnificent.
All the extra gain-up noise disappears, and with appropriate adjustment of the sharpening tool it can minimise some of the wide-aperture lens, enhancing rather than losing edge definition.
Rafael Amador
on Mar 6, 2010 at 12:44:11 pm
Without hesitation, NeatVideo.
But you need a bit of practice and a good monitor to use it properly.
Rafael
http://www.nagavideo.com
