FCS3 to Avid gamma shift - need help!!
Nikolai Va
on Mar 3, 2010 at 12:44:39 am
I have a HD project shot with Red One camera, graded with Da Vinci using pro-HD CRT monitor, exported to ProRes 4:2:2 HQ. It looks wonderful back in FCS3, but I need to export to AVID aaf format (SD-PAL). I have AutomaticDuck ProExport plugin, and Avid MediaComposer mac version installed.
Tried different ways: export with AutomaticDuck, exporting to SD-quicktime with different settings (8-bit uncompressed, DV-PAL, etc, etc...) and importing to Avid MC, - all ways ends with same result: picture looks way darker and contrast in Avid...
Please help! Need to find right way to export ProRes to Avid aaf SD without gamma issues
upd: OSX 10.6
Michael Gissing
Re: FCS3 to Avid gamma shift - need help!!
on Mar 3, 2010 at 12:51:16 am
Did you try 10 bit uncompressed? ProRes is a 10 bit file.
Also are you judging the gamma on both FCP & AVID on an external monitor?
John Pale
on Mar 3, 2010 at 1:14:56 am
Avid has a setting in the import settings for RGB or 601/709 material. Which ever way it's set, try the opposite and see if it helps.
Be aware that some versions of Avid had a bug with this setting where it did not
work properly in all resolutions. You could be encountering that.
Nikolai Va
on Mar 3, 2010 at 1:20:32 am
Thank you, will try to find another version of Avid to try this.
Stefan Engelkamp
on Mar 9, 2010 at 11:20:11 am
We have the same problem here with our Automatic Duck exports from FCP PRORES HQ to DNX185HD. There is a hefty gamma shift when exporting to a MAC based AVID.
Funny enough - it works fine when exporting to a PC AVID.
Looks like the old 1.6 vs. 2.2 problem.
