FCP adding black at end of an export
keith maxwell
on Mar 2, 2010 at 3:25:05 pm
Does anybody know why my FCP whenever I export a film as a dv stream, it exports it ok, but it adds like 5 minutes of black on the end, even though my in and out points do not give an inclination that I want black to be exported.
Has anybody else had this problem and if so how do you rectify?
Thanks in advance
Matt Smith
Re: FCP adding black at end of an export
on Mar 2, 2010 at 4:12:23 pm
Perhaps there is a stray clip somewhere after your desired sequence has ended? I have found in the past that even with my in and out points set, if there is a random audio clip or something way out in the boondocks of the timeline, it will include that clip at the end, with all the black in between.
Smitherd, Geek of Many Shades
Ken Jones
on Mar 2, 2010 at 6:11:58 pm
File>Print to Video>Trailer
Uncheck "Trailer"
Philip Johns
on Apr 20, 2010 at 1:12:38 am
Has anyone found an answer to this? Print to video doesn't help as this is if you're going to tape - we're talking about file exporting. I have selected all clips after the last clip (even though there aren't any) and hit the delete key, marked an out point and exported with the same problem - about 13 minutes of black added at the end.
Philip Johns
