QT movie with separate QT movie as its alpha channel
Lisa Olshanski
on Feb 27, 2010 at 11:01:24 pm
I'm very new to Final Cut. I'm sure this is simple but I just can't figure it out. I have a transition that is a Quicktime and an alpha of the transition as a separate Quicktime movie. So, they are two different clips. I can't figure out how to have my video show through the transition. Can anyone give me step by step instructions on how to do this please?
Arnie Schlissel
Re: QT movie with separate QT movie as its alpha channel
on Feb 28, 2010 at 12:23:47 am
Look up "track matte alpha" in the online manual under the Help menu.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Lisa Olshanski
on Feb 28, 2010 at 1:15:20 am
Thanks so much. Now how do I put a lower 3rd done the same way- 2 Quicktimes- on one video clip? I'm assuming I can't use a transition since I'm not transitioning between two clips.I really appreciate your help.
Bret Williams
on Feb 28, 2010 at 4:28:30 am
Look up nesting next. A sequence within a sequence.
Arnie Schlissel
on Feb 28, 2010 at 5:01:16 am
Same thing. You you use the alpha as a track matte for the fill.
Arnie
Lisa Olshanski
on Mar 1, 2010 at 4:11:25 am
Thanks so much for all your help!
