Firewire raid drive for Final Cut media storage on iMac
Dan Weig
on Feb 27, 2010 at 3:42:04 pm
I'm going to by an iMac Quad-core i7.
I edit in Final cut and I'm looking for a good external drive for media capture and rendering.
Would the 2TB G-raid Esata 400 Rpm Dual Drive with raid 0 FW800 FW800 USB 2.0 be a good option?
Right now I edit DV footage but I'll soon edit HDV footage.
Russell Lasson
Re: Firewire raid drive for Final Cut media storage on iMac
on Feb 27, 2010 at 6:17:49 pm
FW800 is what you'd use to connect to the iMac. FW800 maxes out at around 80MB/sec. Most drives now days are faster than than. So if you get a g-tech 2TB drive or a g-raid 2TB raid, they'll both max out at around 80MB/sec over FW800.
I would suggest just buying the single drive version. Less expensive and less can go wrong with it.
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net
