Print Bin?
jack Bibbo
Print Bin?
on Feb 24, 2010 at 6:54:42 pm
Does this exist in FCP?
jack Bibbo
Re: Print Bin?
on Feb 24, 2010 at 8:30:51 pm
Great I have to purchase something that should be a standard. Kinda ridiculous.
How do people print bins?
Michael Sacci
Re: Print Bin?
on Feb 24, 2010 at 10:14:17 pm
You can always do a screen capture and print that, Not the best and I know that is not what you want.
Yeah we have to buy things we need. Someday everything will just be given to us.
What should be and what is, don't always meet so if you need it you have to buy it.
jack Bibbo
Re: Print Bin?
on Feb 24, 2010 at 10:30:04 pm
The screen capture wont work for our methods.
I am not opposed to buying things that are needed but this is SO elementary that
it is beyond me why it is not included. Maybe I should have to buy a third party plug-in to rename clips.
Until then those that wish to print a bin of a seq that includes the media clips in that seq (media relatives). Do this:
Media Manager / Create Offline - select radio button for "new project". DO NOT DELETE UNUSED CLIPS. DO NOT INCLUDE MASTER OUTSIDE OF SELECTION.
That seq and the clips associated with the Seq will appear in a new project.
Control click the seq and export a batch list. Then print a batch list.
WOW that is a lot of steps but it will print your bin.
Arnie Schlissel
Re: Print Bin?
on Feb 25, 2010 at 2:26:35 am
Look up "batch list" in your FCP manual. You can export a batch list & print that.
I know, you shouldn't have to look anything up in the manual.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
jack Bibbo
Re: Print Bin?
on Feb 25, 2010 at 2:35:54 am
Yep..I just ran through that in the prior post.
The problem with this method however is that batch list does not become selective. So it will batch list everything in the project. And what we need to do is create a list for the clips just in the sequence. This is why you have to consolidate your sequence first into a new project. A large workaround but not the end of the world.
thanks
jack
Arnie Schlissel
Re: Print Bin?
on Feb 25, 2010 at 2:41:23 am
Actually, you can use a batch list to easily list & print a single bin.
Look it up in your manual. The information is there, and it will do exactly what you want with very few steps.
Arnie
jack Bibbo
Re: Print Bin?
on Feb 25, 2010 at 2:47:53 am
Very good...I will have to look into that
thanks!
jack Bibbo
Re: Print Bin?
on Feb 25, 2010 at 2:50:10 am
However...it stills does not solve the media relatives issues. Which is how to show which clips where used in a certain sequence. Put those clips in a bin and then print it.
any ideas??
jack
Arnie Schlissel
Re: Print Bin?
on Feb 25, 2010 at 3:03:24 am
Labels. This question is frequently asked here, and the answer is to select all clips in a sequence and then choose a color coded label from the "Modify" menu. You can sort by these labels in the FCP browser.
I recently used this feature to swap out all of the SD footage in an DVCPro HD feature, for example.
Arnie
jack Bibbo
Re: Print Bin?
on Feb 25, 2010 at 3:11:46 am
But this will only work, sorting the bins by label column, if the bins are open. If the bins are closed or the
project is large and there are bins within bins it will not see them.
I just tried this and it could not find any of my new labled clips because the bins that they were in were closed.
jack Bibbo
Re: Print Bin?
on Feb 25, 2010 at 3:15:34 am
What might be easier is to open the seq, grab all the clips from the seg and throw them into a new bin.
print that bin from batch list. Which I stlll have not seen done.
