While reconnecting offline files, click out of Final Cut and freeze
Matthew Listiak
on Feb 23, 2010 at 4:29:21 pm
I have had this issue in FCP 6 and 7 - when I reconnect offline media and click off of the search window in FCP, I can't get back to FCP. For example, I click File>Reconnect Media; click "Search" and the window comes up to search the finder for the media. If I click out of FCP while that window is up, to the Finder or other application, I can't get back into FCP. It's sort of frozen, but it doesn't exactly crash. It's just stuck with the search window open. I can't cancel it and I can't select any file in FCP. I have to force quit. Any suggestions?
Bob Flood
Re: While reconnecting offline files, click out of Final Cut and freeze
on Feb 23, 2010 at 7:12:26 pm
Matthew
Here are some things i noticed about that
1. sometimes just clicking on any of the final cut panels or panes doesnt bring you back to the application. you may actually have to click the icon in the dock.
2. make sure there isnt a window waiting for a response hidden behinf the reconnect panel, usually one of the warnings about number of tracks, media start and end, and reel number
3. sometimes you have to trash your preferences. if you do not know how to do that, search on this forum.
hope this helps
"I like video because its so fast!"
Bob Flood
Greer & Associates, Inc.
Eric Rhodes
on Feb 23, 2010 at 7:49:59 pm
Just walked through this with Apple tech support on the phone.
First: quit Final Cut Pro.
Second: Follow this path - User Folder (home)/Library/Preferences - find and TRASH "com.apple.finalcutpro.plist"
Third: Scroll down in that same preferences folder and find the folder "Final Cut Pro User Data" and TRASH it.
Restart FCP and it should fix your problem. Worked for me and it had been giving me trouble for a while.
Hope this helps.
Curt Schulz
on Feb 24, 2010 at 1:00:19 am
I've got the same problem... It is some sort of glitch and force quitting and trashing prefs is not the sort of solution I was looking for here, especially since you can't save your project this way. Hope apple fixes this soon.
Curt Schulz
MBP 2.53 4GB Ram/Mac OS 10.5.8/FCP7
John Rogers
on Dec 17, 2012 at 10:22:08 pm
This video pretty explains the glitch.
Hope this helps!
Curt Schulz
on Dec 20, 2012 at 5:55:58 pm
Hi John,
It says its a private video, would like see though!
Curt
Curt Schulz
MBP 2.53 4GB Ram/Mac OS 10.6.4/FCP7.02/Matrox Mini w Max 2.0.0.0150
