ProRes plays smoothly on QTPlayer but Freezes on Final Cut
Rudah de Paula
on Feb 22, 2010 at 8:00:52 pm
I'm having a problem with a ProRes footage I shot with the GH1.
When I use the Quick Time Player it works perfectly, but when I try to play it on Final Cut Pro, the image freezes after a few frames, even though the play head is running.
I'm using a MacPro (2x 2GHzDual Core Intel Xeon, 5GB 667MHz)
Any ideas?
Thank You
Rudah
Michael Gissing
Re: ProRes plays smoothly on QTPlayer but Freezes on Final Cut
on Feb 22, 2010 at 8:53:39 pm
Check your easy setup to make sure they match the codec settings. Also check the sequence settings to make sure they match the codec settings exactly.
Rudah de Paula
on Feb 22, 2010 at 9:28:49 pm
Hi Michael,
Now it's working fine.
Thanks for the help.
Rudah
Michael Gissing
on Feb 22, 2010 at 11:01:08 pm
Thanks Rudah. So many people never get back and say if things are fixed so I appreciate it.
