FCP 7 causing my system to stutter..?
Steve Langmanis
on Feb 20, 2010 at 7:19:10 pm
Hi FCP users,
FCP is causing my system to stutter. Meaning if I play a movie or drag open a regular window it stutters. I have trashed the FCP preferences and user data. I've re-installed FCP Studio twice and still it happens.
I know its FCP because I have used the app 'Maintenance' to reset preferences and the system cache and everything works fine. I can play a movie in Quicktime and it plays as it should. Once I boot open FCP and immediately shut it down. Anything I play in QT jumps, ie, stutters.
Any ideas on what i can do to fix this. I've been trying to fix it for over 8 hours but still no result..
Many thanks for any advice!!
Steve
John Pale
Re: FCP 7 causing my system to stutter..?
on Feb 20, 2010 at 7:53:33 pm
You have not given any info about your system or the codec of the flies you are trying to play
Steve Langmanis
on Feb 20, 2010 at 11:53:01 pm
Hi John,
Sorry your right.
I'm on an Intel 2 x 3 Ghz Duel Core Intel Mac using OS 10.6.2
I've been shooting on Panasonic P2 using the DVCPRO HD codec at 720P 25fps
I've got a RAID system which has been serving me well for over a year, even with 4K files.
The strange thing is that even when I play (mp4) in Quicktime outside of FCP I still get the stuttering.
It seems that just having FCP on my system causes my Mac to be sluggish.
When I run the app 'maintenance' which resets preferences, etc. everything behaves correctly. Once I boot up FCP and quit immediately all the system is again sluggish.
Any advice would be greatly appreciated.
Steve
Zane Barker
on Feb 21, 2010 at 6:41:24 am
[Steve Langmanis] "The strange thing is that even when I play (mp4) in Quicktime outside of FCP I still get the stuttering. "
Sounds like an OS or possibly hard drive issue.
I recommend running disk warrior.
Hindsight is always 1080p
Dave LaRonde
on Feb 22, 2010 at 12:07:03 am
Did you recently upgrade from FCP6 to FCP7? If you did so, do you do a total reinstall of the OS and all software?
Or did you simply do the upgrade,which is not recommended at all?
Dave LaRonde
Sr. Promotion Producer
Steve Langmanis
on Mar 17, 2010 at 8:38:24 am
I've had the system running fine for 4 months. Then suddenly its starting to stutter. Strange. I've now installed OSX on a separate hard drive with FCP 7 on there and reboot to edit. It works but what a pain.
thanks for your advice though. Steve
