Basic Timeline Edit Question - FCP7
kyler boudreau
on Feb 15, 2010 at 6:05:08 pm
Hey - me the Avid Editor learning FCP again. =)
Specs: MAC Leopard / FCP 7 / Mac Pro (tower)
Question: On an Avid timeline I'm used to being able to put and edit and replace/lift/trim content on just the video layer or the audio layer. However in my Final Cut timeline it makes me edit video and audio together - like they are all locked together. I also can't highlight just the audio or video track.
Can anyone show me mercy and open my eyes to FCP's method? THANKS!
_______________________
kyler boudreau
http://www.theatereleven.com
ph.310.425.2231
Shane Ross
Re: Basic Timeline Edit Question - FCP7
on Feb 15, 2010 at 6:19:48 pm
You need to turn off LINKED SELECTION. There are two buttons on the upper left of the timeline, the one on the left that looks like the infiniti sign, or two links in a chain...click that to turn it off.
Shane
John Pale
on Feb 15, 2010 at 6:26:21 pm
Also remember to use the auto select buttons instead of the track target buttons (as you would on avid) for edit operations (such as lift) within the timeline. The auto select buttons are the tiny buttons to the right of the targeting buttons, which are used only for editing from the viewer (source) to the timeline.
Colin McQuillan
on Feb 15, 2010 at 7:44:51 pm
Shift-L is the keyboard shortcut to turn on/off Linked Selection.
It's a good one to set to memory!
Colin McQuillan
Vancouver, B.C.
kyler boudreau
on Feb 15, 2010 at 8:07:01 pm
Thanks guys! This helps...I feel a bit handicapped right now. Used to be a FAST editor. Now I feel like a slug crawling into a fog.
I'll be fast again soon. Appreciate the info! =)
kyler boudreau
ph.310.425.2231
Dave Bergan
on Feb 15, 2010 at 8:25:31 pm
If you option select the clip it will select the specific clip you click on. I've found safer and faster than turning off linking.
kyler boudreau
on Feb 16, 2010 at 4:25:53 am
oh nice...i like the sound of that.
i'm trying to make final cut's timeline work like avid...which means many keyboard short cuts and this constant segment mode stuff is not cool. ARGH.
whatever....gotta learn it.
"And the hits just keep on coming." - Tom Cruise | A Few Good Men
kyler boudreau
ph.310.425.2231
John Pale
on Feb 16, 2010 at 5:58:32 pm
"i'm trying to make final cut's timeline work like avid.."
big mistake. I love Avid (on a Symphony DX right now,actually) but you need to let go. These are two different beasts. FCP is a good editor, but it's a terrible Avid. You will like it a lot better if you learn how it does things and how a different approach can have advantages. You might even learn to appreciate a non modal interface.
