Dissolves and text skip frames when rendered
David Jakubovic
on Feb 15, 2010 at 4:36:58 pm
Very strange glitch: footage shot on P2, 720p 24N. Working with FCP 6.0.6
When I put a dissolve on the footage, it plays fine as long as it is not rendered. As soon as I render it, there is a strange jump right at the very beginning or the very end of the dissolve. Same goes for text tool. The glitch even shows up when going frame by frame.
I tried trashing all render files and re-rendering. I tried duplicating sequences, creating new sequences and putting it in to new timelines - all that. Sometimes the problem seemed to go away but then it started again.
Anyone ever had this problem?
David
"We'll fix it in post"
John Fishback
Re: Dissolves and text skip frames when rendered
on Feb 15, 2010 at 10:38:43 pm
Read David Roth Weiss' post in this thread.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
David Jakubovic
on Feb 16, 2010 at 3:21:03 am
Oh, believe me, I did what he suggests in that post very early on. Nothing work. The workaround I found was to export the clips on which I was doing effects, bring them back in and then do the effect - it worked perfectly then. Very strange.
