fcp work flow advice
hamilton rich
on Feb 15, 2010 at 5:33:03 am
hello,
i receive a lot of content in this nasty MPEG1 Muxed format.
i need to take it into FCP 7 slap a logo on it and out-put it to MPEG4
can any one give me some advice - work through?
i have tried a few different approaches but always end up bad results.
thanx! hamilton
Format: MPEG1 Muxed, 640 x 480 pixels
FPS: 30
Data Rate: 10.5 mbits
Rafael Amador
Re: fcp work flow advice
on Feb 15, 2010 at 1:11:39 pm
Hi Hamilton,
Use MPGStreamclip to transcode the MPG-1.
Export as 8b Uncompress or Prores to avoid picture degradation.
Keep the same size, pixels, fps.
The audio PCM 48Khz.
In FC conform the sequence to the clips.
rafael
http://www.nagavideo.com
hamilton rich
on Feb 15, 2010 at 3:41:41 pm
Rafael,thanks for the tip. what would you set your "Pixel Aspect Ratio" & "Field Dominance"? I tried Prorez 422. What happens is while the clip is playing in FCP its darker color and when i press stop it lightens around three stops. (looks like shit) any advice?
Best regards,
Cw
Rafael Amador
on Feb 15, 2010 at 4:04:46 pm
Hamilton,
MPG-1 use Square pixels and is always progressive (NONE).
When FC is in standby is giving you a poor preview.
To monitor, set the canvas at 100% and render.
rafael
