Multi Channel audio Output in .mov
sridharan balaji
on Feb 13, 2010 at 3:25:23 pm
Hi, I have a sequence with three video tracks and eight audio tracks..... i have doubt is it possible to export this sequence to a quicktime movie which consists of one video and eight audio tracks respectively.......... if so please give me a suggestion........
Rob Grauert
Re: Multi Channel audio Output in .mov
on Feb 13, 2010 at 6:33:29 pm
hmm...I think if you use Compressor you can do this.
When you are adjusting your settings in the Inspector window, In the Encoder Pane change the Audio from "Enabled" to "Pass Through."
Robert J. Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com
