Can't move drive icon or files
J. Tad Newberry
on Feb 12, 2010 at 5:16:08 am
(i posted this on the OS X forum, but no replies, so, sorry to bother you guys with this...)
I have an external FW800 drive on which my info tells me that i have all (read & write) permissions on it, and i can move files to it, but i can't move them from folder to folder while on the drive, nor copy anything from that drive to anything else. i can't even move the drive icon on my desktop. What gives? I'm on 10.5.8
Thanks again!
J. Tad Newberry
Big Ya Productions
Mac Pro 2.66 GHz Quad-Core
3 GB RAM
http://www.bigya.tv
John Pale
Re: Can't move drive icon or files
on Feb 12, 2010 at 6:00:36 am
What is the format of the drive?
Is it NTFS? Is it FAT 32? Is it MacOS Extended?
J. Tad Newberry
on Feb 12, 2010 at 6:04:25 am
MacOS Extended (Journaled) - like my other ones...and i can't even move stuff to the burn folder to clear it off...but i'm sure there is some simple solution.
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
http://www.bigya.tv
John Pale
on Feb 12, 2010 at 6:07:05 am
Are you on a network? Does another station have the drive mounted too?
J. Tad Newberry
on Feb 12, 2010 at 6:09:29 am
hmmm...good point. yes, on a local network, but no other computers have it mounted. in fact, the other two computers are turned off right now.
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
http://www.bigya.tv
John Pale
on Feb 12, 2010 at 6:49:42 am
Maybe your computer still thinks another computer has it mounted…have you tried rebooting or disconnecting from the network temporarily?
J. Tad Newberry
on Feb 12, 2010 at 7:02:14 am
i've rebooted several times, unpugged the drive from this main computer, but so far no changes...
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
http://www.bigya.tv
Rafael Amador
on Feb 12, 2010 at 10:07:29 am
try to eject the disk and mount it with the DiskUtility "Mounting point".
rafael
http://www.nagavideo.com
J. Tad Newberry
on Feb 12, 2010 at 3:30:42 pm
thanks....i unmounted it in Disk Utility, but don't see "Mounting Point"
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
http://www.bigya.tv
Rafael Amador
on Feb 12, 2010 at 3:36:54 pm
Here is the mounting point:
rafael
J. Tad Newberry
on Feb 12, 2010 at 5:24:46 pm
Thanks. I did that, no change. I would try to copy or move these files off this disk and reformat it, but it won't even let me copy any files or folders! Yikes! Actually, i seem to be able to "copy", but i just can't paste anything that is copied from that drive...
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
http://www.bigya.tv
J. Tad Newberry
on Feb 12, 2010 at 8:55:01 pm
Media Manager to the rescue! I took the drive to my other Mac. Same things happened. So now i'm copying files via Media Manager, and it seems to be working. Once that is all done, i'll reformat the drive and start over...but i still wish i knew how to fix this problem. Thanks for your help, though.
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
http://www.bigya.tv
Alan Okey
Re: online and grading a feature in FCP/COLOR
on Feb 12, 2010 at 3:21:17 pm
Although you have verified that you have read and write permissions on the drive, make sure that "ignore permissions on this drive" is checked in the drive info box.
J. Tad Newberry
on Feb 12, 2010 at 3:31:22 pm
it is checked. i also unchecked it, then re-checked it. no change.
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
http://www.bigya.tv
