Alpha Channel from AE into FCP
Christian Heilman
on Feb 11, 2010 at 10:14:16 pm
I was wondering how I could take an Alpha Channel effect into Final Cut Pro. Essentially I will have someone export a page 'peel' out of After Effects. I would like to have that 'peel' reveal an end page that I currently have in a sequence in FCP.
Working w/ FCP 6 and AE CS3
thanks
Michael Gissing
Re: Alpha Channel from AE into FCP
on Feb 11, 2010 at 10:27:46 pm
If AE is on the same computer as FCP 7 then you have a new choice of ProRes 4444 which has an alpha channel.
With FCP6 you have animation codec which also has an alpha channel.
Stephen Smith
on Feb 11, 2010 at 11:25:46 pm
If using the Quicktime, Animations codec be sure to set it to Millions of Colors +. The + stands for the alpha channel.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Alex Elkins
on Feb 11, 2010 at 11:26:29 pm
Hi Christian,
Make sure you select Millions of Colors+ in your render settings (the '+' stands for plus alpha)
The default is just Millions of Colors.
All the best,
Alex Elkins
Salad Daze Films - Freshly Tossed
Read my blog!
