Creating a blanket action for multiple clips
William Barry
on Feb 10, 2010 at 4:50:18 pm
Hello,
I'm in a situation where I need to cut out the first and last second of about 200 clips in order to create a simple cross dissolve between all of the them. Is there any way that I could tell Final Cut to automatically shave the beginning and ending second off of each clip so that I don't have to go in and manually do it myself? Thanks for any advice you could give me.
Cheers
Bill
Jerry Hofmann
Re: Creating a blanket action for multiple clips
on Feb 10, 2010 at 5:26:13 pm
I'm afraid not... If they were still files you can do something along those lines by setting an import duration for them, but not with video.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Arnie Schlissel
on Feb 10, 2010 at 5:39:00 pm
Look up "overwrite with transition" in your FCP manual.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
