"Change clips to match sequence settings"?
Charles Ferran
on Feb 10, 2010 at 2:06:35 pm
How do I get this dialogue to pop up again? I have dozens upon dozens of clips on a timeline and the only thing that doesn't match the sequence settings is the audio, they're both set to 32K but the section under "Audio" says 'one channel' or something like that and the sequence says '2 stereo' so how can I get the sequence to match up to the clips so I don't have to sit here and render? thanks...
Charles Ferran
"Far better is to dare mighty things, to win glorious triumphs, even though checkered by failure than to rank with the poor spirits who neither enjoy much, nor suffer much because they live in a gray twilight that knows no victory or defeat."
Scott Davis
Re: "Change clips to match sequence settings"?
on Feb 10, 2010 at 3:06:18 pm
Create a new sequence with the settings you want. Go to your old one and select all. Copy and paste to the new one. It should ask you the pop up question.
OSX 10.5.5
Quad 2.5Ghz
8.5 GB RAM
Final Cut Studio 6.0.4
HPX 2000
© 2018 All Rights Reserved
