multicam -- dissolves
Jeff Nelson
on Feb 8, 2010 at 4:23:12 pm
Using multicam, have cut a show, want to make every cut into a dissolve. Can do it manually (takes a while). Is there a way to do this globally?
Thanks.
FCP, Mac Pro, 5 gigs ram, 30" monitor, Decklink HD
Jerry Hofmann
Re: multicam -- dissolves
on Feb 8, 2010 at 7:18:06 pm
If you have FCP 7, you can select the clips, and simply add the "default" transition to them all. If not, put the playhead at the beginning of the set of clips, then select the ones you want to add a transition to , and then drag them all up to the canvas and select overwrite with transition.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Jeff Nelson
on Feb 8, 2010 at 7:26:06 pm
Great, thanks, Jerry. Will give it a try. Still using FCP 6...
