compressor encoding progressive
Jon Gagnon
on Feb 4, 2010 at 2:53:31 pm
Hello,
Hope this doesn't sound to newbie-ish.
I'm editing footage that was shot on mini DV that is 30P. It was captured as regular dv ntsc then in the clip settings changed the fields option to NONE. When I export from that timeline it looks great. However when I send to compressor and select progressive it looks like crap, mixing the fields, ants marching look, etc...
Any ideas would be swell...
Rafael Amador
Re: compressor encoding progressive
on Feb 4, 2010 at 3:00:43 pm
Hi Jon,
Had you changed the Sequence to NONE too?
rafael
http://www.nagavideo.com
Jon Gagnon
on Feb 4, 2010 at 4:22:23 pm
Yes
NTSC - ccir 601
no field dominance
29.97
animation codec (there's a few graphics)
I've also tried 8 bit uncompressed.
Rafael Amador
on Feb 4, 2010 at 4:32:59 pm
Try exporting a self-contained movie. Change the sequence codec to Prores.Make sure that in the Options (Sequence Setting> Prores> Options Is not set for interlaced.
rafael
