1080p25 with 1080psf25 on the same timeline, what timeline settings to use
jason morton
on Feb 4, 2010 at 1:28:41 pm
Hi im just about to start a doc where half of the rushes have been shot 1080p25 which is great and the other half 1080 30i, bit of a problem. So i have suggested getting the 30i stuff standards converted via alchemist phc to 1080psf25. Now will these two work together on the same timeline (1080p25 and 1080psf25)and what setting should i go for 1080p or 1080psf. With in mind that I have to deliver 1080p25
Rafael Amador
Re: 1080p25 with 1080psf25 on the same timeline, what timeline settings to use
on Feb 4, 2010 at 2:13:13 pm
Hi Jason,
Once in the computer, the "psf" makes no sense.
Make sure that shows in the Browser as "NONE" and edit in a p25 sequence.
Best,
rafael
http://www.nagavideo.com
jason morton
on Feb 4, 2010 at 2:40:09 pm
Hi, ok 25p it is. i suppose once i have captured the new psf converted source, its all the same (segmented) no field dominance, makes sense, just wanted a second opinion
Thanks, regards Jason
