frame rate issues
Jeff Carbonneau
frame rate issues
on Feb 1, 2010 at 9:52:28 pm
Hope some can help me out with this. I'm edit a lot local car ads, and have just finished cutting my first spot in HD. For delivery, the tv station wants an MPEG2 29.97 frame rate on a data DVD. Fine. I'm cool with that. Here's my issue though. Since I shot it in 24F on my XLH1, does that mean I should edit on a 23.98 frame rate native sequence to the shooting settings. Before my edit, I made my sequence 1920x1080 and 29.97 to accommodate the broadcast specs. And the 1440x1080 XLh1 (transcoded to prores) footage looks fine on a 1920x1080 pro res timeline. Although, when I create my MPEG2 1080 29.97, and play it back in Quicktime and VLC, there's a major difference in frame rate from I'm just watching it back on my timeline. Like there's a frame rate issue going on. It's weird because the 23.98 prores footage on a 29.97 timeline looks fine on the playback monitor. Any help would be much appriciated...
Rafael Amador
Re: frame rate issues
on Feb 2, 2010 at 5:04:52 am
Hi Jeff,
In in Pal land, but if I'm not wrong, you should do your DVD in 23'98.
The Pulldown is added on play to reach the standard NTSC (29,98).
© 2018 All Rights Reserved
