Flashes of black between cuts?
Liam Johnson
on Jan 31, 2010 at 2:05:41 pm
I'm exporting my video and between every cut there appears to be a flash a black.
Is this dropped frames? If so is there anything I can do about this. It's only done it since I worked on the project in Colour.
Shane Ross
Re: Flashes of black between cuts?
on Jan 31, 2010 at 4:50:37 pm
Is the black actually on the media, or are there small gaps in between each cut?
Andrew Kimery
on Jan 31, 2010 at 5:25:13 pm
What frame rate is the FCP timeline you sent to Color and is your footage in that timeline all the same frame rate? There is a problem w/Color and, IIRC, 23.98 media in certain circumstances that causes Color to create black frames at edit points. Unfortunately I can't remember the specifics of the problem but I would post this question in the Apple Color forum here and provide complete details about timeline settings, original media properties, etc..
3.2GHz 8-core, FCP 6.0.4, 10.5.5
Blackmagic Multibridge Eclipse (6.8.1)
Vladimir Uschintsky
on Feb 2, 2010 at 1:30:29 pm
Was recently working with some material shot at 23.98p and needed to output standard 1080i 59.94 and got a black frame between each cut. All cuts in the project were back to back with no gaps. Apple Color wasn't used - just Final Cut. Had to go around Final Cut to solve the problem.
Pearce Roemer
on Jun 23, 2010 at 3:03:03 am
Hey I just ended up with the same problem. First time I've ever had it. I don't know much about exporting to begin with but did you figure it out?
© 2018 All Rights Reserved
