Monitoring HDV footage from an Imac?
Jason O'Hara
on Jan 30, 2010 at 12:18:57 am
Iā€™m currently editing a 1080/60i project in final cut on a 27ā€™ / 3.06 GHz Imac and understand that my imac monitor does not properly display colors and interlacing. What is the cheapest/easiest solution to monitor the true output ā€“ specifically the interlacing?
Michael Sacci
Re: Monitoring HDV footage from an Imac?
on Jan 30, 2010 at 12:38:09 am
You at the older version of the matrox mxo. It uses the DVI port (probably need an adapter). That will give you the truest output. Then you need to have a HD TV.
Shane Ross
on Jan 30, 2010 at 12:39:57 am
He's right. That is the cheapest solution there is. The only other solution is the AJA IOHD, and that runs $3500.
http://magazine.creativecow.net/article/matrox-mxo-broadcast-monitoring-on-...
Shane
Jason O'Hara
on Jan 30, 2010 at 1:22:49 am
what about the Matrox MXO2 Mini which retails under $500? appears it would accomplish same?
Michael Sacci
on Jan 30, 2010 at 3:42:49 am
you need either a PCI slot (desktop) or Express34 slot (some MBP). You only have DVI option which is why your options are limited.
