DVCPRO HD i50 - p25 - DV PAL
Silvia Caracciolo
on Jan 28, 2010 at 3:57:06 pm
Hi everybody,
I look for a suggestion, I read some others posts but I'm not sure to have found what I need.
I'm starting to work on a 200 hours documentary with a Mac Dual 2 GHz PowerPC G5 4 GB DDR SDRAM, with FC 6.5 and a 4TB Raid.(Will it resist along all the editing ? - no graphics, pure editing)
Shoot on:
DV PAL anamorphic
DVCPRO HD 1080i50 (from P2 firestore)
DVCPRO HD 1080p25 (from P2 card, few clips compared to the entire material)
I set my sequence DVCPROHD 1080i50, and I thought to edit all the different formats on different layers, so that I could treat the material easily when they will ask me a different format.
We think the output will be 720x576 4/3, because unfortunately the italian public tv don't broadcast yet in HD, but we want to have the best quality the material can have for future purpose.
1) if I mix material with Upper field and None field will I have problem? It's ok if I change the fields from the browser?
2) if I mix progressive and interlaced clips on a interlaced sequence than I should put some filters?
I will really appreciate any advice you will give me, thanks and sorry for my bad english
Silvia Caracciolo
Editor
Rome, Italy
